Viser resultater 1 til 6 av 6
Tråd: Fitting interior from an S60 R into a ph1 V70
    16. jan. 2011
    Standard Fitting interior from an S60 R into a ph1 V70
    Anyone got any experience in adapting the interior from a later car (S60 R) into an earlier estate (V70R)?.. I've been offered an set of seats out of an S60R, I'm fairly sure the front seats should fit but I'm wondering if I could use the covers off the rear seats to recover the V70R rear seats?
    17. jan. 2010
    Saltdal
    Sitat Opprinnelig postet av Tomcat Vis post
    As i remember Kilroy here on this forum did this conversion to his ph1 v70 But there has been no activity in his thread for quite some time :(
    Verdal`n
    http://forum.vccn.no/showthread.php?...ghlight=Kilroy
    Look at the last 10 pages maybee here
    Moderator Daniel V sin avatar
    05. jan. 2010
    Sarpsborg
    I know he took the dash from a s60R and instrumentpanel, but its not looking good. The dashboard in S60/V70R is allot wider than the firstgen V70. Kilroy tried to modify it. It looks good in his thread, but irl it looks horrible. I dont know about the seats.
    16. jan. 2011
    Yeah I've seen the dash and as you say it probably looks ok from a distance but I doubt it'll look good up close, that and it sticks out into the doorway quite a bit.
    mrstfu sin avatar
    13. feb. 2010
    Rotnes, Norway
    I was told about a trick an old friend of my uncles used to do... heat up each end of the dash, have two guys in the backseat kicking the damn thing into place, and let it cool down. Like a glove
  1. an fitting på FK dyserail.. Hva må til?
    By daols1 in forum Motor og gir
    Siste post: 13/09/12, 09:07
