Thanks Thanks:  2
Viser resultater 1 til 4 av 4
Tråd: V70 2001 seats
    18. april 2018
    Standard V70 2001 seats
    Hello,
    I'm considering changing the seats, and the car has manually adjustable seats. Is it possible to use electrically adjusted seats for the change or does it have to be manual seats? Is there power outlet/plug for adjustable seats in the V70 with the manual seats? I recon the electric seats only need 24VDC power to run the seat-adjustment engines, so maybe it is possible to route power to them, it is not too complicated, but I would rather not my back isn't in a shape for much repairs.
    My pure guess is that the plug bringing the power to the seat heating also has pins for the seat electrical adjustment system regardless if the car originally had electric seats or not. Does anyone know?
    mrstfu sin avatar
    13. feb. 2010
    Rotnes, Norway
    273
    I'm pretty sure you can jusy supply voltage to the seat connector (12V DC, not 24V) and it should work. Maybe make it a switched source so that the seat module doesn't draw power when the key is out. I do think you'l have to load software to retain the memory function though, since this normally adjusts electric wing mirrors as well. Someone else might be able to shine some light on it, maybe Morgis can chime in?
    06. mars 2015
    Fredrikstad
    I had electric driver seat in my 07, and changed from manual to electric passenger, wires already in the car.
    The seats will work with a 12v supply, but memory with the key will not work.
  4. Takk Morgis takket for denne posten
  5. #4
    18. april 2018
    Thanks guys!
  6. Takk mrstfu takket for denne posten
  1. 2001 S60 Ryggekamera
    By Kimmix in forum S60 / V70N / S80 / XC70 / XC90
    Siste post: 24/01/18, 22:31
  2. S60 2001-2009/V70 2001-2007 oppgraderinger
    By Morgis in forum S60 / V70N / S80 / XC70 / XC90
    Svar: 12
    Siste post: 12/02/16, 16:05
  3. V70 2001
    By khbj in forum S60 / V70N / S80 / XC70 / XC90
    Siste post: 16/06/15, 23:38
  4. Fjærbenslager 2001 2,4T
    By amcarduden in forum S60 / V70N / S80 / XC70 / XC90
    Siste post: 24/07/11, 18:38
