Thanks Thanks:  29
Side 4 av 4 FørstFørst ... 2 3 4
Viser resultater 76 til 92 av 92
Tråd: Bluetooth module BT Volvo P2v2 - Oppgradere original telefonmodul PHM med bluetooth.
  1. #76
    Registrerte brukere marekbm sin avatar
    26. mars 2017
    something (maybe this is it) has happened on the wavecom modems (with radio HU-x5x). it was repaired at around october 2017. what version do you have?
  2. #77
    Moderator Morgis sin avatar
    v2018-05-28_1 - I think..will check tomorrow. HU-850.
    '07 V70 R ✓
    '95 850 T-5R
  3. #78
    26. mars 2017
    stupid bug fixed.
    v2018-08-23_1
    Fixed
    - MELBUS: Bluetooth module did ocupate audio lines even if not selected.
  4. Takk Morgis takket for denne posten
  5. #79
    26. mars 2017
    v2018-08-27_1
    Fixed
    - MELBUS: MD-CHANGER text did not work.
  6. #80
    26. mars 2017
    some little improvement.
    v2018-10-21_1
    News
    - Bootloader: If Bootloader is active then pairing is automatically accepted even if accepted by “Green button” is required in standard operation.
    Fixed
    - Modem: Some re-work. Fixed “Connecting…” message on Wavecom modems.
    - Bluetooth: From time to time the message "Synch..." was too long and contacts were not read out.
  7. Takk Morgis takket for denne posten
  8. #81
    Registrerte brukere cortinaterje sin avatar
    03. mars 2010
    Kristiansand
    Sitat Opprinnelig postet av marekbm Vis post
    v2018-10-21_1
    News
    Fixed
    Hi Marek,
    This last update failed. Now the BT module says "please wait" forever. and the MD option on HU is gone.
    What to do now"
    The update was done with a laptop and windows 10.
    Locking the car and wait for 5 minutes, then unlock, did not solve the problem.
    ct
    V70 D5 2002
  9. #82
    26. mars 2017
    if transfer failed then the module boots into bootloader. put the key into position "I" or "II" wait 10 seconds. if
    PHM
    LED not shining then turn on the
    PHM
    . after that send the firmware again. if transfer is ok then it should reboot into standard mode.
  10. #83
    03. mars 2010
    Kristiansand
    PHM
    PHM
    YESS! It works now.
    Thanks a lot
    terje midbrød
    ct
    V70 D5 2002
  11. #84
    26. mars 2017
    little bug fix. if pairing acceptation is not set then it is not reason to update (from the previous version).
    v2018-10-26_1
    Fixed
    - Modem: After pairing is accepted then it is not possible to dial a number from the
    PHM
  12. #85
    26. mars 2017
    i am an idiot. for those who have a revision "F" (mentioned on bottom right corner) then they really have an sound issue (missing bass). the solution is to remove R130 and R131. you can put 100k resistor (0603) instead or keep it unpopulated.
    this is new feature (not in previous versions) but due to CTRL-C CTRL-V error the value is too low (1.5k).
    i am really sorry and i am apologize everyone who have this issue.
    R130 & R131 are shown on this forum.
    Sist endret av Morgis; 30/10/18 kl 22:10
  13. #86
    I got the revC, works perfect.
    What is the "upgrades" between C and F ?
    I see that the revF does not support external bluetooth antenna?
    '07 V70 R ✓
    '95 850 T-5R
  14. #87
    26. mars 2017
    antenna is not affect the revision. i have used modules with external antenna because module + antenna was from some reason much cheaper than module with integrated antenna. and now the situation has changed and module with intergated antenna is much cheaper. onestly i prefer external antenna but with internal it is also easier to install.
    untill revision D the bluetooth module has parts from both sides because it was mostly assembled manually directly by me (and B-D were just cosmetic updates). revision E was the first revision with all parts on the top side (schematic without change) due to cheaper automatic assembly. and the revision F has these new resistors. these resistors just eliminate the noise if bluetooth modem has output in high impedance (it can appears if nothing is connected but radio is selected to bluetooth module). but due to mistake (too low value) it eliminate also basses.
  15. Takk Morgis takket for denne posten
  16. #88
    24. nov. 2018
    Hi Marek. Greetings from Denmark now as well. I would like to order your module and test it before starting the rumor here but how do I order? I have the integrated phone in my 2007 V70 and like the idea of using the already installed equipment. Regards. Anders.
  17. #89
    26. mars 2017
    only small things
    v2018-12-24_1
  18. #90
    245 V8 sin avatar
    29. jan. 2012
    Ørsta
    Flere som har montert denne og er fornøyd? Vurderer den i V70en.
    Volvo 164E B30E -72
    Volvo 245GLE 5.7 V8 -81
    Volvo 240GL Turbo B230FT -93
    Volvo V70AWD D5 Summum -05
    Volvo V90 T8 Inscription -18
  19. #91
    06. mars 2015
    Fredrikstad
    Hadde den montert, ikke vært fornøyd i lengden. Hadde et problem med lyd ut på samtaler som jeg aldri fikk løst. Volumet vekslet mellom normalt og mer eller mindre helt borte. Musikkavspilling var aldri noe problem.
  20. #92
    Stryn
    Eg har den i bilen, var ikkje fornøgd med telefondelen og mistenkte at kvaliteten på Bluetooth audio ikkje var heilt på topp så eg endte opp med å koble den frå og bruke grom audio boksen eg hadde frå før.
    Meen, so daua både radioen og grom adapteren i løpet av eit år så når eg bytte radio og tok i bruk telefonen igjen. Eg brukar kun det til Bluetooth audio, for samtalekvaliteten er heilr ræva, men det er hardwaren i bilen som er problemet. Det er steinalder..
    2005 Volvo Horisont B12M
  1. Bluetooth og AUX adapter til original SC og HU spillere
    By Morgis in forum Produkterfaringer
    Siste post: 09/04/18, 02:02
  2. Oppgradere original telefonmodul PHM med bluetooth.
    By MadAss in forum S60 / V70N / S80 / XC70 / XC90
    Svar: 47
    Siste post: 17/12/17, 21:46
  3. Bluetooth og original spiller.
    By Cadnet in forum S60 / V70N / S80 / XC70 / XC90
    Svar: 22
    Siste post: 25/01/15, 22:35
  4. Ettermarkeds dobbel din spiller med bluetooth control ala Volvo?
    By eMTea in forum Bilstereo og Multimedia
    Siste post: 22/06/14, 22:05
  5. Svar: 0
    Siste post: 19/06/14, 22:12
