Side 1 av 2 1 2 SisteSiste
Viser resultater 1 til 25 av 34
Tråd: Abl lyser S80 2012
    12. april 2011
    osterøy
    432
    Standard Abl lyser S80 2012
    Abl lyser gult får opp krever service noen gode tips?
    Volvo S80 D3 2012 summum
    2019 Fendt Brilliant 700 sga
    Drar ut lykta og ser etter at det ikke er noen kabler som har hoppet av/knekt inne i den. (vanligere på de tidligste P3-bilene)
    Er alt tilsynelatende ok, så ser du litt på feilkoden...
    12. april 2011
    osterøy
    432
    B104321 cem feilkilde fikk jeg Hva er det?
    Det trodde jeg du kunne se i diagnoseprogrammet ditt
    Normalt sett skyldes
    CEM
    -B104321 en defekt nivåsensor ved høyre framhjul, eller feil på kabeltilkoblingen. (skader/korrosjon)
    Men her er Volvos forklaring på
    ECM
    -B104321:
    CEM
    -B104321 Front Axle Sensor. General Signal Failures. Signal too low
    Diagnostic trouble code (DTC) information
    CEM
    -B104321
    Condition
    The central electronic module (
    CEM
    ) checks the signals from the position sensors.
    The diagnostic trouble code (DTC) is stored if the control module detects that:
    The signal from the front position sensor is less than 3 % of the supply voltage.
    The control module's test for the diagnostic trouble code (DTC) starts in the event of:
    Voltage supplied sensor.
    Vehicles without Four-C.
    Note! The control module can only detect the fault once the test has been started and the diagnostic trouble code (DTC) is stored when the conditions are met.
    Substitute value
    Constant light beam length will be used.
    Side control freezes straight ahead.
    Possible source
    Short-circuit to ground in the power supply.
    Contact resistance, oxidation or poor contact in connectors or connections.
    Short-circuit to ground in the signal cable to the front / rear position sensor.
    Open-circuit in the signal cable to the front position sensor.
    Open-circuit in the voltage supply lead to position sensor.
    Damaged sensor.
    Hint:
    If both diagnostic trouble codes
    CEM
    -B104321 and
    CEM
    -B104421 are set at the same time, then check the voltage feed to the sensors for short-circuiting to ground since the lines are internally interconnected in the central electronic module (
    CEM
    Fault symptom(s)
    9T, Headlights/Vertical adjustment not influenced by steering wheel
    DC, Headlights/Headlight aim is off
    12. april 2011
    osterøy
    432
    Takker og bukker for svar skal se litt på det i morgen
    12. april 2011
    osterøy
    432
    Jiha du har ikke tilfeldigvis bildet av giver bakaksling.har vida men men🤣🤣🤣
    Hva, har den rømt, så du trenger bilde til etterlysningen?
    Den kommer jo som regel ikke så langt avgårde, henger vanligvis og dingler et sted rundt venstre* hjuloppheng bak, ligner litt på den foran
    EDIT: *ehh, høyre...
    Sist endret av jiha1968; 01/06/21 kl 15:49
    12. april 2011
    osterøy
    432
    Hvor finner jeg ny til en normal pris da?
    Ja, det er ikke så godt å si, men nyeste delenummer tror jeg er 31288274, med tidligere nr: 30669855, 30782270, 30782821, 4251193909991, 5203730
    Her er et par direkte lenker: Skandix og Ebay
    Men var det ikke sensoren foran det var feilkode på, eller er den bak i ferd med å gå samme vei?
    EDIT:
    Sensornumrene jeg skrev over her er til sensor høyre bak...
    Riktig delenummer til sensor venstre bak er 31288273, og erstatter gamlere 30657419, 30782271, 30782820.
    Sist endret av jiha1968; 31/05/21 kl 22:11
    12. april 2011
    osterøy
    432
    Jiha vet du om delen fra en 2005 kan passe?
    Det høres veldig tvilsomt ut, tror det er mer sannsynlig at en sensor fra Ford Mondeo eller
    P1
    -chassis (C30/V50) vil passe, enn noe fra
    P2
    -chassiet.
    Hva har skjedd med sensoren bak? (du sa ikke noe om kode på den?)
    12. april 2011
    osterøy
    432
    For lavt signal
    12. april 2011
    osterøy
    432
    Ny koster den 2200 på Volvo men ikke lett finne den brukt
    Det å finne bruktdeler på delenummer her i Norge er en utfordring, ser ikke ut til at huggerne er interessert i å bruke tiden på det.
    (dette fungerer av en merkelig grunn adskillig bedre i Sverige)
    Om du vil ha tak i noe brukt lønner det seg ofte å se etter nyankomne biler og be huggern sjekke og plukke, om det ikke er noe i nærheten med selvplukk.
    Men dette er kanskje ikke delen man først og fremst velger bruktversjonen av, da de fleste har trege ledd i staget, om den ikke er byttet nylig, eller kun gått høyt til fjelds i innlandet...
    (jo det er stive priser for en enkel sensor)
    PS: om du har feil på begge sensorer, bør du sjekke om strømtilførselen er ok til sensorene
    12. april 2011
    osterøy
    432
    Har bare cem b104421 nå for lavt signal
    Fremdeles en ide å sjekke realitetene på sensoren (strømtilførsel, tilstand på kontakt osv) men mest sannsynlig så er du på rett spor med ny sensor ja.
    12. april 2011
    osterøy
    432
    Jiha kan det være samme del på V70 2008mod sensoren bak?
    Bak, på førersiden har V70
    FWD
    (P3) til og med chassis nr. 24894 er det sensor 30782271, deretter sensor 31288273.
    Din S80 bruker sistnevnte: 31288273 , så om ikke V70-08'en har lavere chassisnummer enn 24894 så skal sensoren passe.
    (samme ch.nr-skille på sensor høyre bak)
    Har ikke sjekket, men jeg misstenker at det er mer fysisk utforming av festeplater og stag som skiller, enn selve sensoren
    PS: Har rettet opp info i tidligere post på delenummer til sensor bak, hadde kun listet høyre bak...
    EDIT: ser at det for øyeblikket ligger en sensor hos Østfold Bildem. fra en V70 08, den har ch.nr19736 og burde ha "for gammel" sensor til din bil, men ser at huggern har merket sensoren med "ditt delenummer", så det blir jeg ikke klok på...
    Sist endret av jiha1968; 31/05/21 kl 22:16
  19. #19
    12. april 2011
    osterøy
    432
    Jiha har bare en sensor på høyre side jeg.kan ikke se noe på venstre sida
  20. #20
    12. april 2011
    osterøy
    432
  21. #21
    Ok, på høyre side er det fortsatt 31288274,
    med tidligere nr: 30669855, 30782270, 30782821, 4251193909991, 5203730 som gjelder så vidt jeg vet.
    Og angående samme sensor fra V70 P3, så er det som sagt et skille ved chassis-nr 24894,
    men om det kun dreier seg om fysisk utforming på stag og braketter eller selve sensoren, det vet jeg ikke.
  22. #22
    12. april 2011
    osterøy
    432
    Jiha hatt av sensor i dag og notert ned det som sto der kanskje du kan hjelpe meg der?
    Står FoMoCo 8G9N-5A955-BA under står det BL3KA dette forteller meg ikke mye hehe tenker på nr du har gitt meg tidligere
  23. #23
    FoMoCo-nummeret (8G9N-5A955-BA) er nummret på selve sensoren,
    som du kan bruke ved f.eks søk på bruktdel.no eller ebay.
    Fordelen med det nummeret er at du finner samme sensor fra alle biler som bruker den, f.eks Mondeo.
    De Volvo-delenumrene du har fått er for sensor inkl montasjemateriell, mener at Volvo ikke selger løs sensor.
  24. #24
    12. april 2011
    osterøy
    432
    Kan kanskje få fatt i bare sensor da?
  25. #25
    Ja så lenge stag og braketter er ok, så må det være en grei løsning
  1. 2012 XC60 venstre fjernlys lyser ikke
    By steinrawr in forum x60 / V70II / XC70II / S80II
    Siste post: 18/09/20, 16:33
  2. Svar: 383
    Siste post: 22/08/13, 22:12
  3. Svar: 308
    Siste post: 29/01/13, 00:59
  4. Svar: 6
    Siste post: 13/04/12, 11:12
