Viser resultater 1 til 2 av 2
Tråd: Olje på turbo intake
    04. april 2018
    Standard Olje på turbo intake
    Hei,
    2011 V70 DrivE - got the wagon back from EU kontroll last week and noticed this oil on turbo intake https://www.instagram.com/p/CKo5uaBpafx/
    What do you fellas reckon - is this an issue, or normal oil spray accumulation?
    04. mars 2018
    Bjugn
    Hi, PCV-hose connected to turbo inlet hose is sweating, repair or exchange hoses, or be cheap and clean it now and then until it gets worse.
    Check crankcase pressure/excessive piston ring blowby, by carefully lift oil fill cap when engine is idling.
    (some blowby is normal, but if cap flies off then...)
  3. Takk krist1980 takket for denne posten
  1. Olje på V70 turbo
    By Aleks in forum 850 / x70 -serien
    Svar: 7
    Siste post: 23/11/18, 22:09
  2. 850 2.0 turbo bruker litt olje turbo som er gåen?
    By Bjørnstad in forum 850 / x70 -serien
    Siste post: 06/10/14, 22:34
  3. Intake Air Tempsensor '99 B5254T
    By mrstfu in forum 850 / x70 -serien
    Svar: 12
    Siste post: 14/12/13, 09:16
  4. bytte av lt turbo til høytrykk turbo. problem med returrør av olje.
    By 1987_Turbo745 in forum 700 / 900 / x90 -serien
    Siste post: 29/05/12, 19:28
  5. Svar: 5
    Siste post: 02/05/12, 22:18
