Viser resultater 1 til 4 av 4
Tråd: S90 lowering
    16. jan. 2011
    Standard S90 lowering
    Anyone got any links to anywhere I can get parts to lower an S90?
    Mysen, Østfold
    chassit.se sells a lowering kit, but it is not tüv approved if that is a requirement.
    The kit consists of front springs and shocks + rear gas shocks.
    It lowers the front maybe a bit too much (basically no air gap at all between the tire and wheel arc), the rear is depending on what spring Your car is fitted with.
    Volvo has 3 options for the rear leaf springs:
    -gas shock spring, in which the spring holds the entire weight of the car.
    -nivomat spring, in which the weight is partly hold by the spring and partly by the nivomat.
    -sport chassis, which is the same as the nivomat but a bit lowered.
    Lowering the rear is the tricky part, the following will work:
    -Nivomat spring with the nivo's replaced by gas shocks.
    -Shortened gas shock spring.
    The oem lowering spring will not work without the lowering nivomats. With gas shocks it will basically rest on the bumpstops.
    07 Opel Zafira OPC "bussen"
  3. Takk Tomcat takket for denne posten
  4. #3
    16. jan. 2011
    Does that site specialise in just Volvo's?.. doesnt really list models... either that or google translate isn't doing it's job properly.
  5. #4
    Registrerte brukere ss242 sin avatar
    17. mars 2010
    Årnes/Akershus
    453
    Try this link: http://chassit.internetbutiken.net/kprodukter.asp
    Search for article number GEV112001
    Not possible to link directly to products :(
